go full gay and buy some Uggs ?
I'd recommend some smarter chukka boots with rubber or preferably dainite soles. If you buy the right pair (not desert boots) then they can look like normal shoes under trousers. Something like the Loake Pimlico would give a good idea although you probably wabt to find a cheaper boot if it's just for work. But the Pimlico in leather is quite a sleek boot so just throwing it out there as an example of what to look for.
Just wear better socks.
I have these and they are def not gay looking, very warm and waterproof
"I'm not gay but my boyfriend is"
Its not gay unless you finish inside!
