spec me some watercooling
Hi,
I'd look into this kit:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-080-TL&groupid=962&catid=1532
Mounted on top of the case. No need to go overkill like 10x480mm radiators as you are about to cool only single CPU and GPU(s??). Not sure if your current setup is already GTX780Ti and you want to buy another for SLI, or you have not yet bought it.
For waterblock for GPU I would ask OC'ers through webnote, as I've no idea if waterblocks will fit non-reference cards. Each waterblock for GPU will be around 40-100, and I suggest you go with either XSPC or EK as brand (good quality).
If your card is the Zotac GeForce GTX 780 Ti OC 3GB GDDR5 (ZT-70505-10P/ZT-70506-10P) then according to XSPC's cooling configurator the EX-FC780 GTX Ti waterblocks should fit.
So main components could be:
YOUR BASKET
1 x XSPC AX360 Triple Fan Radiator (Black) £89.99
1 x EK Water Blocks EK-FC780 GTX Ti - Nickel (Original CSQ) £79.99
1 x XSPC AX240 Dual Fan Radiator (Black) £74.95
1 x EK Water Blocks EK-D5 X-RES 140 CSQ - Acetal £59.99
1 x XSPC D5 Vario (Body + Screwring) £54.95
1 x XSPC RayStorm CPU WaterBlock (Intel) £49.99
Total : £419.46 (includes shipping : £8.00).
You'd just need to add tubing, fittings (dependant on layout for angled/rotaries) and fluid.
Most of that is just personal preference really. Some people prefer different manufacturers over others, usually for aesthetics.
