I've only had my 360 for two days and already I'm looking at how to improve it
. The main limitation I've got at the moment is using the bog-standard analog jacks for audio, whereas I'd like to use the digital 5.1, but I'd also like to rig up my MythTV box to my main speakers instead of using the rubbish built-in ones on my monitor. Here's what I've got:
PC + X-Fi Platinum
MythTV box + Audigy 2
Xbox360
Creative Inspire 6.1 6700
At the moment I'm using 5.1 analog outputs from the x-fi into the inputs on the 6700, and also using a splitter on the front input to connect the 360. Ideally what I'm after is a decoder box like the Creative DDTS-100, but I can't find it anywhere apart from the Bay where they go for ridiculous prices. The alternative is to get the Logitech X-5500 set, but I don't really want to spend that much and I don't think my room is big enough to accommodate it, let alone warrant 500W+. Does anyone know of any alternatives I could go for - either a smaller speaker set with a built-in decoder or a standalone decoder box? Just the product name will do, I can usually find out where to buy it myself
PC + X-Fi Platinum
Xbox360
