Spec me.. Sound system!
29 Dec 2009
Anybody feeling helpful? :)
Had enough of poor quality speakers in my car and so I've decided it's time for an upgrade.
I won't be fitting the system myself, so most likely will buy the products from Hallfrauds and get them to fit it?
I don't know much about audio, but apparently you need a head unit with 2x pre-outs if you want both an amp and sub? Is that right?
Total budget is £350-400
Would like sub/amp/head unit/front speakers.
As said, I've not experience whatsoever and not feeling taking my car apart myself because it probably won't go back together again once I'm finished :p
