Spec me: Soundcard + Speakers
26 Nov 2003
Brentwood
My Onboard soundcard is rubbish, I also need new speakers.
I'd like a pretty decent soundcard, and the same with speakers. 2.1 Would be awesome.
Looking for bang for buck here.
Cheers :)
Had abit of a fuss with SB before, locked my pc up on install. Then made it run like it had 1mb of ram.
Mmmm..
Usual reccomendation for 2.1, although you haven't set a budget, the Acoustic Energy Aego M 2.1. If you have quite a high budget definately consider Hi-Fi though :)
Heh just kinda bought a pair Dark_shadow.
I'll look into that card! Cheers for the alternative advice :D
Nice one, as for the card . . I'll kinda take my words back as OCUK have them pretty dear atm.
Especially considering when they were pretty knew I bought them for arounds £38 from this very place :D
Around your budget though, X-FI should be a good choice.
A second hand Audigy 2 or similar card should be fine and can be had for around £15 :) . If you need the X-Fi features then go for that, if not your just paying extra for them.
