SPEC ME Spray paint.
20 Nov 2006
Well i want to spray some parts of a computer case, whats the best way of going about doing this and whats the best spray paint to pick up for doing the job.
Thanks.
Halfords, self etching primer if you're painting bare metal, some high grit wet and dry sand paper, whatever colour paint you want and some clear lacquer.
From what I remember about rattle cans, halfords were always the best. i still dont think any rattle can is ideal but we shal not go back into that one ;) lol
Nein!
If I had your talent/gear I would agree. :D
I can only get rattle cans though...so my 2nd machine will be going Beige + steel to Black all over when I can grab some rattle cans...and know what is the right type to go for.
InvG
