Spec me system in ROCKET ALUMINIUM MINI-ITX CASE
@peterhc - more information would be helpful. Budget? What will the machine be used for? If you have a monitor already and intend gaming, what resolution will you be using? Do you need any peripherals? Why do you prefer Intel?
budget is around £600-650 my gf needs system that will run division 2 in high settings, I've spare 1080 so I'll need mobo cpu mems cooler psu and nvme ssd?
Oh and resolution is 1440p 60Hz
thanks
no one xD?
This is at 1080p with 2080ti but shows TD2 doesn't mind extra cores :)
https://www.overclock3d.net/reviews/software/the_division_2_pc_performance_review/6
You can get a 2600x for the same price else where or cheaper
My basket at Overclockers UK:
Total: £639.10 (includes shipping: £13.20)
Raijintek case is better designed, glass and cheaper ! Also allows 240 AIO up top and 120mm fan at the bottom !
Gigabyte board is UK RMA unlike others with rep support on here .
Antec PSU is on a heavy sale and 10 yr warranty and fully modular Seasonic unit
