- 1 Sep 2005
- Scottish Highlands
In a couple of months, I will be needing a water loop for my 'ultimate' rig, so I thought I might as well get some ideas and suggestions now. What im after is a waterloop for a DX10 card(I know there not out yet, so the waterblock might have to be left until they are) and a northbridge chip.
Im currently running on a MSI K8N diamond board, but will be moving to a Kentsfield setup in the not too distant future. Don't worry about the CPU cooling as this will be taken care of by a custom Phase unit, all built into a LianLi v2000.
Ideally im wanting to run the loop off a 120.1 rad internally at the back of the case. Will this have enough cooling capacity for the components? I'd also like to run a T-line rather than a ras as I won't have enough space for a res(All the 5 1/4" drive bays will be full of harddrives and DVD-RW)
So what NB block/Pump/120.1 rad/Fill port/tubing etc do you recommend? im basically after the best money can buy. Also what tube size should I go for?
Thanks.
Thanks.
