- 16 Nov 2005
Hello all,
Im looking to rebuild the new pc i built im just having to many fualts and errors with this pc since it was built. Im hoping OCUK will let me send the products i bought off them back so i can reorder diffrent parts.
Im looking for a pc which can play the latest games at good fps at 1024x1280 i want a card where i can run dual screen prefrebally a card with dual dvi and good ram. I was thinking a X800GTO or X800Xl becuase they are cheap and good cards. I will probobally be upgrading the card when the new DX10 cards come out.
This pc will mainley be used for gaming dvd burning and encoding and decoding. Downloading, using mirc. Main games i play are CSS and Battlefield 2.
Current specs are
Amd opteron 144 @ stock
DFI SLI-D
Giel 2GB ram
Hiper 580W modular
ATI X800GTO
Samsung Spin Point 80GB SATAII
Hitachi 250GB Deskstar IDE
NEC DVD RW
ThermalTake Armour
Thats already a good spec but the pc is messed up i dont know whats wrong with that pc.
I was thinking of going dual core and getting another Samsung 80GB if budget allows to do RAID. Only parts i dont want to send are the hdds.
Well what specs can you do.
Thanks.
Current specs are
DFI SLI-D
Giel 2GB ram
Hiper 580W modular
ATI X800GTO
NEC DVD RW
ThermalTake Armour
Thanks.
