Spec me up a fan controller
4 Apr 2004
Pontypridd
Recently changed from a sugo sg01 with noctua 80mm fans (q6600 set up) to a Lian Li PC-A05FNB i5 3750k. I've also gone from a 4890 vapour-x to a 7950 vapour-x. As the pc is in my bedroom silence is preferred, therefore I have stumped up for a Zalman CNPS20LQ CPU Liquid Cooler and changed the fans in the case to Scythe Gentle Typhoon 120mm 1850 RPM.
However, I'm finding the noise a little hard to take. Even with the lowest possible settings within the bios, it's a little too loud, whilst still idling @ 25 - 28. What I'm looking for is a simple fan controller (in black) which will allow me to control 4 fans (cpu x 2 (push pull)) front exhaust and top. This is where i get confused! I don't want flashing LEDS, I don't want LCD displays, I don't want temperature sensors.
I simply want 4 knobs which allow me to turn the fans from an off setting to a maximum setting (for gaming), can you recommend something?
