Spec me up a graphics card :)
23 Oct 2002
Some where, out there
I'm running a 9800PRO at the moment, on my 2.4 northwood, and I'm feeling the upgrade bug. I don't need anything bleeding edge, as I only tend to play Eve online, and it's not all that graphically intensive.
New card must have / be :- as quiet as possible (current system is watercooled), have DVI-D, be £100-130, and.... well, that's about it. Could be looking at upgrading the chip and board too, so PCI-E is also doable.
You won't get a massive speed boost with the amount of money you have to spend but you could go for a 6600gt in AGP form and fit an Zalman cooler although this won't be hugely better. Maybe try looking secondhand and see if you can get either a 6800gt or X800 series card(not the X800se) for about your price range as they would be about as good as you'll get in AGP.
This is pretty close to price & matches everthing else you asked for (it is PCI-E).......
Sapphire ATI Radeon X800 GTO Ultimate 256MB DDR3 TV-Out/DVI (PCI-Express) - Retail (GX-096-SP)
Push your PC’s performance threshold and remove unwanted distraction with the ULTIMATE Silent solution in the Sapphire RADEON X800 GTO ULTIMATE!
- 400MHz GPU Clock Speed
- 256MB 980MHz GDDR3 memory accelerates the latest cutting edge 3D applications
- 256-bit quad-channel GDDR3 memory interface
- Twelve pixel pipelines
- Six programmable vertex shader pipelines
- Fanless silent cooling solution for complete silence!!
Price: £119.95 (£140.94 Including VAT at 17.5%)
As he's got a P4 2.4 he'd probably want an AGP card :)
In that case I'd try to stretch to the PowerColor ATI Radeon X800 GTO 256MB DDR3 TV-Out/DVI (AGP) - Retail (GX-050-PC) for £150
