semi-pro waster said:This is well under the budget so if you need an OS or want to choose a nicer case or better clocking Ram then you have that option but for the price you have a very fast system at stock
CP-127-AM AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail (ADA4400CDBOX) (CP-127-AM)
£284.95 £284.95
GX-047-HT HIS Excalibur ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-047-HT)
£299.95 £299.95
MY-006-MK Mushkin 2GB DDR EM3200 Enhanced Performance Dual Channel Kit (2x1GB) CAS3 (991461) (MY-006-MK)
£114.95 £114.95
MB-129-AS Asus A8R-MVP Crossfire (Socket 939) PCI-Express Motherboard (MB-129-AS)
£69.95 £69.95
CD-026-NE NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Black) - OEM (CD-026-NE)
£27.95 £27.95
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£65.95 £65.95
HD-048-WD Western Digital Caviar Special Edition 200GB 2000JS SATA-II 8MB Cache - OEM (HD-048-WD)
£51.95 £51.95
Subtotal £915.65
VAT £160.24
Total £1,075.89
bbK said:Thanks not to sure about the X2 cpus... might slightly adjust that.
semi-pro waster said:What are you not sure about? You effectively have 2x 3700 San Diego chips on one core so it is fast in single cored operation but will excel for multitasking or dual core specific programs. You could choose a dual core Opteron if you want to go for larger overclocks maybe and you do get 2mb L2 cache but otherwise the X2 4400 is a good CPU.
bbK said:What do you guys think? pros/cons if any?
bbK said:Ok i edited my last post with the updated gfx are we all good now
I also have another question the GFX card is using a DVI port to connect the monitor right? well on my monitors i dont have a DVI port is there an adapter of some kind i can get?
Explicit said:lol, happy now
The graphics card will include the adaptor that you need![]()
bbK said:
Are you 100% sure about the GFX coming with the adapter?
i dont want my new rig delivered saturday and not being able to use it till monday lol![]()
bbK said:Oh ye and this should be the last question... the pc im on right now i want to hook up to the net with the new rig so im wanting a wireless router, what exactly do i need to setup both pc's on th wireless connection? (sry ive never done this before)
bbK said:Thanks a lot !
