Spec me up scotty (Conroe)
11 Jul 2003
Telford//west mids
Ok i have sold all my AMD parts to make way for a Intel conroe setup.
First of all cooling will be mach 2 gt or air.
Parts that i need are as follows.
Cpu E6400/E6600 or the E6700
Good overclocking motherboard
DDR2 2GB Kit
I have about £800 to spend on the above items.
Thanks for looking :)
How much you lookin at spending??
If really overclocking you wanna get a Intel Bad Axe Motherboard
Stelly
Is it a totally new system or are you taking anything out of your current pc to use?
Complete build:
CP-127-IN Intel Core 2 DUO E6400 "LGA775 Conroe" 2.13GHz (1066FSB) - Retail (CP-127-IN) 1
£154.95 £154.95
MB-010-IN Intel Extreme D975bx-304 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-010-IN) 1
£139.95 £139.95
MY-014-GS G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS) 1
£114.95 £114.95
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE) 1
£52.50 £52.50
CD-038-PO Pioneer DVR-111DBK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM (CD-038-PO) 1
£21.95 £21.95
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN) 1
£65.95 £65.95
GX-061-PC PowerColor ATI Radeon X1800 GTO 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-061-PC) 1
£119.95 £119.95
Subtotal £670.20
VAT £117.29
Total £787.49
Complete build:
£154.95 £154.95
£139.95 £139.95
£114.95 £114.95
£52.50 £52.50
£21.95 £21.95
£65.95 £65.95
£119.95 £119.95
Subtotal £670.20
VAT £117.29
Total £787.49
I like it but would put a X1800XT on it instead :)
Stelly
You asked for scotty? I'm here :p
You only need a CPU, mobo, and RAM right? If so...
DFI Infinity 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-020-DF)
£129.95
G.Skill 2GB DDR2 ZX PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBZX) (MY-011-GS)
£149.95
Intel Core 2 DUO E6700 "LGA775 Conroe" 2.67GHz (1066FSB) - Retail (CP-129-IN)
£349.95
Subtotal £629.85
VAT £110.23
Total £740.08
Look good? Damn right it does :D
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£252.57
£164.44
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£173.84
Total inc VAT: £590.85
I don't think the E6700 is worth the massive price increase, but you can easily fit it into your budget.
Yeh just need cpu,motherboard and ram :)
So g.skill is the ram to go with then
Motherboard intel and Dfi,been hearing good things about the intel board,not so much about the Dfi.
As for the cpu cooling i may be keeping my mach 2 gt :D
Thanks for the replys people.
£252.57
£164.44
£173.84
Intel's website doesn't say that mobo will support a Core2 Duo processor.
With Mach II:
CP-129-IN Intel Core 2 DUO E6700 "LGA775 Conroe" 2.67GHz (1066FSB) - Retail (CP-129-IN)
£349.95 £349.95
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£149.95 £149.95
MY-013-GS G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£147.95 £147.95
Subtotal £647.85
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £8.25
VAT £114.82
Total £770.92
With air:
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95 £214.95
£149.95 £149.95
£147.95 £147.95
Subtotal £512.85
VAT £91.20
Total £612.30
Concorde Rules said:
It does, people have been breaking World Records with it...
Ok. If you were building a conroe/crossfire system, would you choose this mobo over the Asus P5W DH Deluxe?
I've heard Asus have great build quality so I've been kind of Asus centric in my search for components.
The biggest attraction, in my opinion, that the Asus has over the Bad Axe is that it does not suffer a performance decrease when using the 1333fsb boot strap because of decreased chipset latency.
The DFI is limited to the 1066 strap, meaning a max fsb of around 370mhz.
The Asus is hitting 440-450mhz fsb consistently with better performance than the Bad Axe.
Bah I would like to see those figures :)
Stelly
As Kez said...
Conroe E6600
= win. Though that Asus is bloody pricey at £175! :eek:
I would add:
OCZ GameXstream 700w (available online)
Just ordered this myself, and its basically the FSP 700w with a much quieter fan and a few other options. Will last ages and cope easily with R600 and future CPU's. It's had amazing reviews, and is a good investment imo.
I've seen several people on the forum forking out on a £400-£800 CPU and I can't imagine anything more horifically pointless and wasteful personally. Max overclock will be very similar to the E6600 and isn't that what overclocking is all about... getting the most for your money? Not to mention the amount the very expensive CPU's will de-value in a very short period of time. Just can't see the point in them personally, paying that much for a CPU goes against every overclocking principle I hold dear. :)
Asus P5W DH Deluxe WiFi over the Bad Axe anyday. Asus have been the best boards for Intel rigs since day one.
We only saw a load of records set by the Bad Axe because thats the only board that was availible pre-release.
E6600 (best buy for the price)
Simple enough... its the setup Ive had noted down since Conroe's were on the scene... now just need the money to get it all and start to play...
E6600 is definitely the best value for air or water, e6700 is better for phase however to avoid running out of fsb. :)
Just done some searching ad in germany the Asus P5W DH Deluxe WiFi costs only £130... a stonking £45 cheaper than here. Why the huge price difference? :confused:
