Spec me up Scotty.
11 Jun 2004
Around £700 pounds to play with, with around +- £200 either way.
For CPU, Mobo, memory and graphics card.
Pci-e and ddr2 preferred. Best valued spec for price preferred.
Thanks lads :)
fenny
I'd probably go for something like this. Sorry I don't have time to sort out the horrible formatting the new website gives here.
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL) £173.99
(£204.44) £173.99
(£204.44)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR) £17.99
(£21.14) £17.99
(£21.14)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN) £107.99
(£126.89) £107.99
(£126.89)
Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (MB-062-GI) £104.99
(£123.36) £104.99
(£123.36)
Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO) £209.99
(£246.74) £209.99
(£246.74)
Sub Total : £614.95
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
Vat : £109.18
Total : £733.08
Dunno about RAM and Mobo but I'd definitely get these
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN) --- £229.11
Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-CO) Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-CO) --- 170.36
Total Inc VAT and Postage : £409.17
Which leaves you £300 to play with for mobo and RAM.
(£204.44) £173.99
(£204.44)
(£21.14) £17.99
(£21.14)
(£126.89) £107.99
(£126.89)
(£123.36) £104.99
(£123.36)
(£246.74) £209.99
(£246.74)
Sub Total : £614.95
Vat : £109.18
Total : £733.08
Looks good, thanks matey :)
Can I just get confirmation on the compatability between cpu, mobo and memory by someone please?
cheers :D
Ya CPU and Mobo are 100% compatible. The ram should work fine as all the Geil's are working well with the DS3/DS4. I know CPU and Mobo will work 100% and the DS4 will get that CPU overclocking very nicely.
The ram i am 90% sure it will work, i just remember something about Voltage problems with some DDR2 Modules but im sure the geils were fine.
Other than that, you have yourself a lovely build.
Some of the GSkill(apart from the HZ series and maybe even higher up the range) refused to work properly with Gigabyte motherboards although I believe they were fine with everything else so that could be what you were thinking of. :)
