Hi all, got a new car and want to get a new install going.
I work for myself at the moment and currently don't really take a wage so money is a BIG factor.
I'm also hoping to possibly use some existing parts that i have.
What i have so far:
Nissan 200SX S14a 2 litre turbo
with standard speakers and headunit throughout.
2 x Vibe QB69 Square 6x9's (No where to place them in my car)
******'s Power Cap (Un used)
Loads of gale 105 speaker cable from my old home cinema setup
Loads of Vibe bass speaker cable (from my old speakers)
Vibe FD4 Fused Distribution block (1x4AWG input and 4 x 8AWG output)
1 x long 0 gauge wire with fuse holder attached
1 x Fusion NV-SW12 (1000wrms) (This is better than the other fusion tat (encounter etc...)
1 x Fusion Powerplant Mono channel 2000W Amplifier
1 x Fusion Powerplant 2 channel 900W Amplifier
So as you can see, i have a fair few bits from existing car builds etc...
I will be making a boot build for the sub and hiding the amps etc...
What i was thinking was to get a 4AWG and run it from the battery to the fused distro block and then out to 2 8AWG wires to go to each amp but i have this 0AWG so would that be better to use? By using the 0AWG, it would render the FD4 useless due to the inputs on it.
I did have some Vibe BlackAir 6's to go into my old car (Brand new) but my cousin being the thieving **** that he is, stole them and i have no way to prove it was him so i need some new speakers too for my doors and for my parcel shelf which NEEDS to be the right size due to the parcel shelf having a metal shelf underneath and i don't fancy cutting and chopping bits up.
As i already have the sub, bass is no major issue, so just want something to give me clarity and obviously ideas on which wire etc... to use whether it be the 0AWG and find a way to split off to the amps or to get a 4AWG and use the FD4 block etc...
So in summary, i need some decent speakers (comps?) specced and ideas on the best way to wire it all up including which wire to use, to use the FD4 and if to use the power cap?
Thanks in advance for your help.
Andy
What i have so far:
Andy
