I dont need a full new system. PSU is fine, case is fine, OS is fine, HDD is fine, everything.
all i *think* i need is MB, CPU and Ram. I have two 8800gtx's lying around so if SLI is a option it would be good.
I basically wondering if a sub £400 upgrade would increase my speed that much. My Pc is relatively vintage, its a AMD X2 4400 939socket, with DDR1 and its Asus whatever motherboard. So the 3 main components are useless.
Id rather switch to Intel, and id rather have a intel chipset (this rules out SLI though?
) DDR2 or 3 doesn't really matter. So would an upto £400 upgrade performance that much? or should i just keep saving?
Thanks.
) DDR2 or 3 doesn't really matter. So would an upto £400 upgrade performance that much? or should i just keep saving?Thanks.
