Our Indesit has decided its bearings have had enough after a good decade. Unfortunately it's not old enough that they're serviceable without replacing the drum. So now I need to get my head around 10 years of "progress" and buy a new one.
Unfortunately user reviews don't seem to fare well for most budget to middle-of-the-road models due to the machines trying to think for you and calculating wild wash times. I'm not keen on this at all, but seems like they all do it (presumably some eco reasons) so maybe we need to change with it. We only use 2 settings on the current machine plus the delay timer so not looking for much in innovation, just a reliable washer that won't take 3 hours. Frankly if I could fix it I'd be perfectly happy to use it another 10 years.
Anyway, our current machine is 8 kg 1600 spin, but looks like 9 kg 1400 spin is probably the sweet spot. Current contender is the LG F4V309WSE although similar models with 10x the reviews (FCV309WNE) seem to bring up a fair few complaints like other machines about wash times a bit of cheap quality in areas.
Anyone bought a new machine recently for ~£500 that they can recommend?
