Spec me: watercooling! :)
J86
J86
23 Aug 2005
I'd like to spend under 200 quid (maybe stretch to 250 if its worth it) and get the best possible cooling for my i7 (and perhaps connect it to my 4890 at a later date).
I'm pretty clueless when it comes to water cooling so thought I would ask here first :)
I've been using a NorthQ Siberian Tiger kit for my Q9450, but would like to have a custom set-up for my i7.
I'll be requiring a single or dual rad, as I don't have enough space for a triple one in my case. I quite like the look of the drive bay reservoirs, as they're out the way, but if they're no good then don't worry :P
Also, I would like black tubing if possible as I am going to have UV orange coils around it.
Thank you for your time :)
HK 3.0 > PA120.2 or RX240 > DDC pro with XSPC res top
But do some research and start an MM wanted thread for the pump and rad.
Block you'll need to by new.
What cooling did you used for sig temps?
you either have a very cool running chip or don't mind fan noise.
240 rad is fine with a single block on i7 (but not a cool & quiet loop)
