Spec me what Components you use to built this HTPC case with
Caporegime
27 Nov 2005
Guernsey
I just ordered this HTPC case and am now looking around for what PC Components am going to need buy to built it
(I aready have a spare 720w PSU & some 3.5" hardrives to put in it)
http://www.silverstonetek.com/products/p_contents.php?pno=gd02mt&area=
So can any you guys recommend or spec what Components you use ??
It also going be used for gaming on my 1080p TV screen..
Your basket
Product Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £173.99
(£144.99) £173.99
(£144.99)
Asus P8H67M-EVO Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) Asus P8H67M-EVO Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) £99.98
(£83.32) £99.98
(£83.32)
OCZ Intel Extreme XMP 4GB (2x2GB) DDR3 10666C7 1333MHz Low Voltage Dual-Channel Kit (OCZ3X1333LV4GK) OCZ Intel Extreme XMP 4GB (2x2GB) DDR3 10666C7 1333MHz Low Voltage Dual-Channel Kit (OCZ3X1333LV4GK) £29.99
(£24.99) £29.99
(£24.99)
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) £19.39
(£16.16) £19.39
(£16.16)
Sub Total : £269.46
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £55.79
Total : £334.75
This what I'd put in right now, if money is no object.
This is what I'd bung in on a budget.
Your basket
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £69.98
(£58.32) £69.98
(£58.32)
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail £46.99
(£39.16) £46.99
(£39.16)
(£24.99) £29.99
(£24.99)
(£16.16) £19.39
(£16.16)
Sub Total : £138.63
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £29.63
Total : £177.76
Graphics I'd leave up to you, whatever card is going in there will get a bit toasty methinks. I'm not certain if the cooler I specced will fit in that case either.
Think it needs to be a P series board to go with a K series cpu for overclocking
(But i don't think any cpu cooler that will fit in this case will be able to keep the heat down for overclocking)
But an i5 cpu is what i was thinking of going for ;)
It can only take up to a 70mm high cpu cooler
(But i don't know how wide a cooler it can fit till i receive the case and fit a motherboard in to measure it)
Am hoping one these coolers will fit
Scythe Shuriken Rev.B Quiet Low Profile CPU Cooler (Most likely this one)
Scythe Shuriken BIG Quiet Low Profile CPU Cooler
Not surprising you forgot. It's a bizarre situation.. I guess we'll have to wait for the Z-series mobos which can overclock and use the onchip GPU..
Don't think i need an onboard GPU..
As i should be able to output to the TV & the front mounted LCD at the same time from a single GPU card ..
:( Ordered this case at about 6.30am last friday morning and they no got around to shipping it yet :(
Note: this is Not from OCuk........as they do not sell this silverstone case)
