Spec Me!!!
27 Jan 2005
I'm giving up on PC gaming, and thinking of going the Xbox 360 route.
I'm curious though are there monitors that work on the X360 that OCUK sells? I have a normal non HD TV, but cant be bothered buying a big huge TV yet and would be happy with a 19 inch or 20 inch monitor thing for the xbox 360.
I also don't want an X360 if am just going to play it on my normal tv as I want the quality resoloution!!!
Could some one spec me a good 19inch under £200 and one 20 inch under £300. Widescreen I assume would be the better option.
Thanks.
Belinea 1925S1W 19" Widescreen LCD Monitor
The Belinea 1925 S1W is a wide-screen display in a comfortable 19 inch format that stands out with a short response time and an excellent contrast ratio. The Belinea 1925 S1W is ideally suited to depicting wide websites, double page texts, multimedia applications or parallel applications as there is no need to scroll from left to right. A response time of just 5 ms guarantees smooth pictures for video sequences, a contrast value of 850:1 sharp and true-colour images. The innovative TN+Film panel combines the advantages of the fast TN with the high quality MVA technology and thus provides users with a wide viewing angle. The 1440 x 900 pixel resolution guarantees an impressive image experience.
- 1440 x 900 Optimum Resolution
- 16.2 Million Colours
- 850:1 Contrast Ratio
- 5ms Response Time
- 300 cd/m2 Brightness
- One Analogue Input
- Integrated Speakers
- Warranty : 3 year on-site warranty supplied by Manufacturer (Call Belinea direct for all support and RMA issues on 01344 788920)
Available This Week Only for just £109.99 +VAT.
Belinea 102035W 20.1" Widescreen LCD Monitor - Black/Silver (MO-003-BE)
The Belinea 10 20 35W is the first MAXDATA screen with a wide format. Users looking for more horizontal space on their screen will be delighted with this monitor. Websites are displayed better because you no longer need to scroll from right to left working on wide film sequences is easier and it is also possible to display various applications on the screen at the same time. Up to 4 devices such as a digital camera external disk drive or keyboard can be easily connected via the integrated USB port. The very short 8 ms response time integrated speakers and the additional DVI connection also make this display perfect for multimedia use. Featuring the latest panel AU O offering unbeatable visual quality and performance making this LCD monitor ideal for gamers, home cinema and performance users.
- 1680 x 1050 (WUXGA) Optimum Resolution
- 16.7 Million Colours
- 800:1 Contrast Ratio
- 8ms Response Time
- One DVI-D Input
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
Available This Week Only for just £209.99 +VAT.
Price: £214.99 (£252.61 Including VAT at 17.5%)
Remember you will need to buy an X360 vga cable also
