Spec me....
4870 + accelero s1 rev2 + noctua fan strapped on.
You speak wisdom.
Is there a cooler just as good for a 260?
I'm inclined to go for that becuase my current ATI drivers seem to be raping my audio, which is very important seing as my upcoming build is a studio PC primarily.
260 is a bitch to change the cooling on (although the stock cooling is pretty good and not that loud - unless the fan revs up a lot).
If you really want the quietest possible then it would have to be a 4870 with aftermarket cooling or a watercooled 260 (which probably wouldn't come into your price range).
