Spec me...
21 Sep 2008
A medium spec pc, to maybe run bf 2142 in medium to high detail
around £300-£400
i have a cpu cooler.
monitor if can be included?
:confused:
apparently the gpu needs to be one of the following:
otherwised reduced performance in BF 2142
ATI
Driver tested: Catalyst v6.7 Windows XP
Radeon 9500/9700 series
Radeon 9550 series
Radeon 9600 series
Radeon 9800 series
Radeon X300 series (non integrated versions)
Radeon X600 series
Radeon X700 series
Radeon X800 series
Radeon X850 series
Radeon X1300 series
Radeon X1600 series
Radeon X1800 series
Radeon X1900 series
NVIDIA
Driver tested: Forceware v91.31 Windows XP
GeForce 5800 series
GeForce 5900 series
GeForce 6200 series
GeForce 6800 series
GeForce 7300 series
GeForce 7800 series
GeForce FX 5700 series
GeForce FX 5900 series
GeForce FX 5950 series
what socket(s) does your cpu cooler fit?
newer GPUs will work, as none of the GPUs above are really available or worth buying anymore
everything included except optical drives
not sure if you already have any or need to buy new ones
LG775 ? not sure, it came with a core 2 duo E7200
probably not that good, thought it might cut costsss
Your basket
Product Name Qty Price Line Total
Viewsonic VX1940W 19" Widescreen LCD Monitor £84.99
(£73.90) £84.99
(£73.90)
Asus M4A78 AMD 770 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard £59.98
(£52.16) £59.98
(£52.16)
AMD Athlon 64 X2 Dual Core 5200 2.70GHz (Socket AM2) - Retail £51.74
(£44.99) £51.74
(£44.99)
XFX ATI Radeon HD 4650 1GB TV-Out/HDTV/HDMI (PCI-Express) - Retail £47.99
(£41.73) £47.99
(£41.73)
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) £40.99
(£35.64) £40.99
(£35.64)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £40.99
(£35.64) £40.99
(£35.64)
Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) £39.99
(£34.77) £39.99
(£34.77)
Akasa Rev.4 Zen Case - Black (No PSU) £36.00
(£31.30) £36.00
(£31.30)
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £16.99
(£14.77) £33.98
(£29.54)
Sub Total : £379.67
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.25
VAT is being charged at 15% VAT : £58.94
Total : £451.86
inc monitor, but is 50 over budget.
user1453's spec is much better for gaming, but i tried to fit everything you need for a new build in my spec while allowing for easy upgrades in the near future, hence the lower performance
