Spec me....
27 Sep 2004
Glasgow
A method of nuking some spiderz!
For the past month or so I've been getting constant webs and spiders floating around my cars wing mirrors. I've washed the car several times, making the effort to properly hose down the mirrors, trying to flush the buggers out. Nothing has worked, every morning there's a new web around the mirror and generally a large string of it attached to both cars on the driveway.
These past days it's been pretty warm so after using the car I've left the windows open ever so slightly. On returning there's usually more than one spider inside the car. It freaks the other half out when we're parked up somewhere with the window open, the little buggers just keep finding ways in undetected.
What do I do? I'm assuming the nest is behind the wing mirror - inside the mirrors casing, if that makes any sense.
I was assuming you were just using a sponge and bucket. If you're sure they're behind your mirror you might need to actually try and take it apart and wash it that way.
Take the mirrors off and set them on fire, then roundhouse kick any spiders you see.
Heh.
My wing mirrors have spider housing estates built into them too, I think they like them because they're heated mirrors and are still warm after the car is off.
I get rid of them with the pressure washer though from one edge forcing them to exit the other edge in a wave of soapy water!
