Spec Me...
7 Jul 2009
Newcastle/Aberdeen
...a soldering iron. For electronic work (obviously), as cheap as possible but i don't want it to melt in my hand. What accessories should i have? Stand, heat proof mat etc. but what about those weird 'crocodile clip magnifying glass' things? Thanks :)
Try not to skimp on quality as the cheap ones are a load of carp, I got one of an auction site for about £5 only wanted it to join a couple points on an xbox motherboard and it was honestly useless seemed to heat up but wouldnt melt the solder until about half way up the tip of the iron
I find a small table vice to be more useful then one of the third hand magnifier clamp jobs but I don't use one very often.
