Spec me...
Why do you want to spend that much? You do realize Port should be drank straight away and isn't like whisky where you can dip into it over a few weeks/months right?
The older years taste better.. Even I can tell that!
And it won't be dipped...it will be shared and finished after dinner with some good cheese :cool:
Well that's a total lie, you're a marketeers wet dream but never mind.
What type of Port do you want?
I just assumed if you were spending that amount of money then it would be a gift rather than to be drank.
As a general rule vintage port needs 40ish years of ageing to be at it's best. Great cheese and fine port go hand in hand and great to share with people.
Thanks Justin... Worth another 50 on the 63's?
I've not ever tried a 63. I'd personally go with the 70 or 77 as I doubt there's much difference between them and the 63 to warrant the extra. The 77 was declared 9/10 and the 70 8/10.
