Spec Me:
14 Nov 2012
Chesterfield
I'm looking to replace my 2x 200mm CoolerMaster White LED fans with 2x 200mm Bitfenix Spectra Pro BLUE LED and would like to know if these would suffice?
Otherwise, can you spec me an alternative?
If they are the same size, which they are, its fine
Google for reviews dude.
They are a good all purpose fan, I was impressed with the 140mm versions I was given to review their Hydra Pro led/fan controller that I replaced my other fans to match
