Spec my friend a build! £650 max
6 May 2014
Hey guys,
My friend is looking to get into PC gaming. He has a monitor, and the cost of windows is separate from the £600-£650 budget. He's asked me for help picking parts, but I'd rather ask here so he can get the most out of his budget.
Cheers
YOUR BASKET
1 x KFA2 Geforce GTX 770 2048MB GDDR5 PCI-Express Graphics Card - OEM (77XPH6DV6KVX) £179.99
1 x Intel Core i3-4350 3.60GHz (Haswell) Socket LGA1150 Processor - Retail £104.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Avexir Gold Series 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CEY) - Yellow/Gold Light £65.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £61.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £39.95
1 x Raijintek Agos Midi Tower - Black £39.95
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £656.42 (includes shipping : £8.00).
or better CPU/slightly worse GPU, probably the better option
YOUR BASKET
1 x Powercolor Radeon R9 280 TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £155.99
1 x Intel Core i5-4430 3.00GHz (Haswell) Socket LGA1150 Processor - Retail £134.99
Total : £662.42 (includes shipping : £8.00).
I wouldn't spend £50 on a water cooler for a cpu that can't be overclocked personally.
The pallit 970 is a bit cheaper, but the MSI has a better cooler and power delivery for overclocking.
I do also think the build needs a ssd rather than the cheaper bigger mechanical hdd for a better experience in general.
I think an AMD build is completely pointless now. Theres no upgrade paths at all and AM3+ is effectively a dead socket, but athlonxp's first build + SSD would be great
