Spec my mate!!
1 Dec 2005
okMy mate would like to up grade his computer, so this is what he needs:
Mobo (must be PCI-E)
CPU
RAM
HDD (150gb at least ...)
His budget is £200, is that possible? Also he know hes wants and AMD, but i know the AM2 has jsut be realeased, how are they looking?
thanks :D
EDIT- Also he will be building in his Dell dimension case (yes super cool :rolleyes: ) , now is taht a mATX case or a normal ATX??
Runningkid said:
hmm ...... i think £350 is pushing it too much , he sed 250 is max...
AMD Athlon 64 3000+ Venice 90nm (Socket 939) - Retail (ADA3000BPBOX) (CP-117-AM)
£72.79
Asrock 939Dual-SATA2 (Socket 939 & Upgradable to AM2) AGP & PCI-Express Motherboard (MB-002-AK)
£43.42
OcUK Value 1GB (2x512MB) PC3200 184pin DDR Memory Dual Channel Kit (MY-004-OK)
£56.34
Hitachi Deskstar T7K250 NCQ 160GB SATA-II 8MB Cache - OEM (0A31637) (HD-001-HI)
£50.47
Total inc VAT: £223.03
Overclock that and you have a winner for that price!
Impossible, especially considering this...
Runningkid said:
{snip}EDIT- Also he will be building in his Dell dimension case (yes super cool :rolleyes: ) , now is taht a mATX case or a normal ATX??
Apart from that, what else does he have: GFX, keyboard, etc?
£72.79
£43.42
£56.34
£50.47
Then you can not go wrong with that :)
Nice little AM2 rig :)
CP-162-AM AMD Athlon 64 3000+ 1.80GHz (Socket AM2) - Retail (CP-162-AM)
£66.95 £66.95
MB-145-AS Asus M2NPV-VM Micro ATX (Socket AM2) PCI-Express DDR2 Motherboard (MB-144-AS)
£59.95 £59.95
MY-000-PA Patriot Signature 1GB (2x512MB) PC5300 667MHz DDR2 Dual Channel Kit (PSD21G667K) (MY-000-PA)
£55.95 £55.95
HD-025-SA Samsung SpinPoint P HD040GJ 40GB SATA-II 8MB Cache - OEM (HD-025-SA)
£25.95 £25.95
Subtotal £208.80
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £8.25
VAT £37.99
Total £255.04
Runningkid said:
sorry for double post, any 1 know how these AM2 3000+ performs?
the AM2 performance is comparable to the same named 939 chip, marginally quicker but nothing you'd notice.
HOWEVER the advantage of going AM2 is that you get the current, therefore longer supported, socket.
Runningkid said:
oh ... so would this be a bottle neck, if say ... he got a 7600GS or something?
It won't really be a bottleneck as you should be able to overclock the venice (bare in mind that nobody has a clue about how AM2 motherboards overclock atm)
I'd also consider a larger hard drive if you prefer BigDom's AM2 spec which is more future proof and upgrade-able. Bare in mind that AM2 holds a 1% performance gain over socket 939, so a 3000+ venice on the new socket AM2 will be perform virtually the same as a 3000+ venice on the mature socket 939 :)
