My Mum is in need of a new computer to replace the laptop that she currently uses. She doesn't move the laptop around at all, so a normal desktop computer will be fine for her.
She literally only does MS Word 2003 work and browses the internet with it.
Needs to be nice and quiet as well - she doesn't play any games at all so something like the 8400GS heat pipe card would be perfect.
Not sure on a budget at the moment, but if you can keep it around £300 then that'd be good.
She doesn't really like changes on the computer, and doesn't like learning anything new on the computer so I'm going to put XP on there for her. May as well go for 2GB RAM as it's so cheap anyway.
Don't need screen/mouse/keyboard.
Has to be nice and reliable!
Thanks,
Craig.
Thanks,
Craig.
