Ok so, my current rig is:
lian li v600
i7 920 d0
fenriririr cooler
3x2gb ocz i7 ram
rampage 2 extreme
gtx 280 (would upgrade)
I want small, I mean, a tiny pc. but one that can hoof out the power I need (3d modelling,rendering/games, so high end gfx and high end cpu.)
I'm looking at that zotac h55, and an i7 860 (yes different socket to my d0)
then I'd be able to snug it into a tiny case (lian li q08 for instance which can take up to 300mm for a gfx card)
Would the 860 give me the same power as the 920? Most benchmarks seems equal with the 860 pulling ahead (on stock) a tiny bit. A heft OC wouldn't bother me, currently sat at stock anyway, wouldn't mind a nice 3.6+ oc from the 860 though?
My only other thought is a shuttle (im waiting on the j3...) but I can see that costing a bomb, and if im right triple channel ram doesnt reallly do much benefit? So I could just whack in 2x4gb and be done.
So whats the 860 like?
whats the zotac like? (anything else to rival it?) Just seen a dfi p55 itx, mmmm
Anyone else got anything similar?
lian li v600
i7 920 d0
fenriririr cooler
3x2gb ocz i7 ram
rampage 2 extreme
