Spec Please - Accounting PC
28 Sep 2004
Devon, UK
Hi there,
I'm so out of the loop with the latest CPU/Mobo I thought it best to ask you guys on a basic spec accounting PC.
Small case preferably (Mini/Mirco-ATX)
Small HDD only needs to run Sage
Wifi Adapter or built into Mobo
Cheap as possible really
Thanks,
Mark
Something like that looks perfect, thank you.
Would it be worth changing the Seagate 1TB HDD to a Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G)?
Also on the case I've had a look myself but there isn't anything I'd call a desktop/small case that's below £70. The only other option I can see i the OcUK value case with PSU.
Thanks
