Spec plz!
13 Oct 2007
Cotswolds
Hello all
I wondered if you could speak me a PC with the following:
An E8400 CPU, appropriate Mobo (X38??) and some RAM - i want to be able to achieve about ~ 4Ghz if possible.
I also need a gfx card (possilby GTS 512Mb or GTX as i game @ 1920)
I got a WDRaptor/Seagate .11 for HDs
Would also like a new optical drive, is a BLuRay player a good investment or stick to a plain DVDRW?
Also need a new OS, Vista - 32 or 64bit - which one would give me better performance? I may get 4GB RAM in the future
I also have a 700W Modular PSU to power it all :D
Thanks :D
Matt
wouldnt bother with blue ray at the moment , stick with dvd-rw.
go for a gtx being as u're running @ 1920.
if you're going for vista go with the 64bit.
might help too know the budget for the mobo etc.
Would all of this work together:
e8400 + LG775 cooler
4GB DDR2 Crucial B. PC8500 (id like the 8500 as i dont want to push the ram 2 far)
8800GTX OcUK
Vista 64bit Home Premium
SATA DVDRW Drive
and either: ASUS Maximus Formula, MSI X38 Diamond or Asus P5E ??????
Thank you.
yup no obvious reason why not as far as i can see.
can't really advise about the x38 mobo's, best bet is have a looksee in the mobo forum see whats going on.
you want too go for the 4ghz might want to think of a tuniq cooler or similar.
