Spec Questions
5 Jan 2005
not far from OChq
Hi
I will be getting these in next few weeks an i wanted to ask a few questions before i part with my money.
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series
http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC
Abit Fatal1ty FP-IN9 SLi nForce 650 (Socket 775) PCI-Express DDR2
http://www.overclockers.co.uk/showproduct.php?prodid=MB-124-AB
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-126-IN
1. Would my Enermax Nosietaker 485w PSU be enough to handle this along with an x1950xt?
2. Would i see a huge improvement over my amd 4000+ at 3050ghz?
3. Is the mobo good for overclocking or do u recommend any other (below £120)?
4. Is the cpu any good for overclocking or should i get the 6400?
Thanks.
Edit: damn, i just noticed this was in the wrong forum, could a mod move it please thanks.
1) Yes it is ok with your rig
2) No unless you overclock, in fact an A64 sandy @ 3Ghz is better in most apps than an E6300 @ stock. But you will definetely notice the difference in multitasking.
3) Under £120 and overclockable: DS3 / P5N-E / P5B-E
4) E6300 is very ocable when coupled with a decent mobo, if you want to make sure that mobo FSB doesn't hinder your overclock get a CPU with higher multi like the E6400 or E4300.
