Spec Recommendation - £650 budget.
23 Apr 2014
Looking to build a PC purely for gaming. I do not need keyboard, mouse, OS or monitor. It will be used mostly for Steam games.
£650 budget however it can go a little over.
full amd build:
YOUR BASKET
1 x MSI Radeon R9 280 Gaming 3072MB GDDR5 PCI-Express Graphics Card £199.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £83.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £74.99
1 x Toshiba SSD HDTS212EZSTA 9.5mm 128GB Solid State Hard Drive - Retail £65.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £53.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £49.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x Antec Kúhler H2O 650 Liquid CPU Cooler £29.99
1 x LiteOn IHAS124-14 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £665.89 (includes shipping : £12.50).
of course there is more than one way to skin a cat and you can go for an intel build too, but you'd be sacrificing some parts for that:
full intel build but ofc its 100 quid overbudget (but would be the one i'd recommend - if you can stretch that far)
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £82.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
Total : £761.90 (includes shipping : £12.50).
nerfed intel build to fit the budget:
YOUR BASKET
1 x VTX3D Radeon R9 280 3072MB GDDR5 PCI-Express Graphics Card £189.95
Total : £654.98 (includes shipping : £11.75).
you don't get:
the cooler (so you can't overclock straight away)
slightly worse cooler on the graphics card
lose the ssd
If budget is going to be adhered to, I'd go with an AMD build to get a good balanced rig, like Tamzzy's spec shows. Then in the future if you want more CPU power, you could sell just the motherboard and CPU, and go i5/i7.
Said who? At least back up your statements ;) If you're going to spend £75 on mobo might as well get the 990 chipset..
YOUR BASKET
1 x Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £239.99
1 x Gigabyte 970A-UD3P AMD 970 (Socket AM3+) DDR3 Motherboard £67.99
1 x Seagate SSHD 7200RPM 3.5" 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DX001) SSHD Hybrid Drive £59.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £55.99
1 x Corsair Carbide Series SPEC-03 Mid Tower Gaming Case (CC-9011052-WW) £45.95
Total : £663.86 (includes shipping : £12.50).
Has a 280X which great for gaming for years to come. a 6300 which can be overclocked to a decent speed. To fit the 280X in the build I picked a SSHD over the SSD. The speed from the SSHD will be decent but the overall PC will be much better because of the great Graphics Card.
