Spec Required
23 Jun 2007
South East
Hello chaps!
The noise from my R9 290 is driving me insane so I'm considering moving to water cooling.
My current spec is below (excuse the long names, take from orders page).
Sapphire Radeon R9 290 4096MB GDDR5 PCI-Express Graphics Card
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor
Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Patriot Venom Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz
Corsair Carbide 540 High Airflow ATX Cube Case - Black
Corsair RM Series RM 650 '80+ Gold' 650W Power Supply
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler
Could I potentially keep the CPU on the H100 and just put the GPU on water as a start?
I was thinking of a triple rad at front of the case then potentially a double in the top to replace the h100 later on?
Any suggestions and how much would I be looking at to switch?
Ok lets get the ball rolling..
How does the following look so far? Inspired by Skittles build seen here.
I'm a little confused/lost when it comes to fittings. I think I am OK to use standard compression without any angles however would appreciate someone looking over and confirming?
Could save a few quid with an EX360 to match the other rad rather than the AX.
you will be fine with comp fittings. There is 1 90degree on the bottom rad in that build. Always worth getting some 90 & 45 degree fittings IMO. They are all compatible with the compression's.
