I've been asked to spec up a new PC for a friend (well his dad to be more precise), However, I've received the usual answers to my "What does he use it for" / "What is his budget"questions. Being "he uses it for everything (not gaming)" and "he doesn't want to spend too much, but wants it to last 5 years and doesn't mind spending a little more" - GAH
So what i thought I would do is give 3 options (budget / mid range / higher end) then inevitably have them chop and change it. The problem is I'm well out of the loop when it comes to current tech (I'm still running a 3750), so I'm not sure of the benefits of the newer intel / amd offerings.
Here's where I need your help people of OCUK!!!
Whats Needed
Uses - Netflix / Browsing / Book keeping / light desktop publications /emails ect
Budget - I'm not sure myself here, but if we say £350 / £500 / £700 (budget/mid/high)
Thanks in advance!
Whats Needed
- Simply the base unit (they will reuse current monitors / keyboard / mouse / Windows key)
- Graphics Card - I'm aware onboard will do the job perfectly in the case, but they are anal about this and want a card because the old one "lagged"? But any cheap one will do.
- An SSD (+ possibly a larger storage drive in the higher specs)
- No requirements on the case so whatever the budget allows
Thanks in advance!
