Ive got an E8500, with the DFI X48 UT mobo. Its in a Antec 1200 case, and i want to watercool this little badboy.
So guys its upto you to spec me the BEST watercooling loop JUST for the cpu. Im running my 4870's with the HR03-GT + 92mm Sharkloon silent eagle's, and Zalman ramsinks so the gfx isnt a problem.
Also ive got some OCZ Flex ram, but i dont think its really worth watercooling these.
The DFi passive cooling should be more than enough with the airflow from the 1200 dont you think? (its the top end model with the heatpipes)
I was looking at the swiftech 220 all in one jobby but its well dated now.... This is my first watercooling adventure
Foxor-
Edit: Full Spec (so far)
Antec 1200
Seasonic X900 900w
E8500
DFI X48 UT
OCZ Flex 9200 (4gb)
Gainward HD4870's x2
HR03-GT x2
Zalman Ramsinks x2
Sharkloon Silent Eagle 92mm x2
Foxor-
Antec 1200
Seasonic X900 900w
E8500
DFI X48 UT
OCZ Flex 9200 (4gb)
HR03-GT x2
Zalman Ramsinks x2
i dont think thats going to be good enough to get nice temps with 4ghz + clocks ?!
(the 360mm versions)
