Hi,
I'm trying to help a friend spec a gaming PC, with some slightly testing requirements.
Basically, the remit is low power consumption, quiet as possible but be able to play GW2/Titan at 2560x1440 on max settings.
Budget is in the region of £1500-1700 (including monitor)
I've had a look about, getting some ideas but I reckon you kind gents are able to assist more ably....
So in summary:
Budget c. £1500-1700
Green, silent, high power
No need for an OS
Would like SSD + mechanical data drive
Blu ray
Monitor - either 2560x1440 or 3D 120hz @ 1920x1080
Thanks
So in summary:
No need for an OS
Blu ray
Thanks
