Spec will this fit in a midi case?
18 Dec 2007
XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card x2
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Asus P8Z68-V PRO Intel Z68 (Socket 1155) DDR3 Motherboard
Lepa B-Series 750W '80 Plus Bronze' Modular Power Supply
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-8GBXM)
Corsair Hydro H80 High Performance Liquid CPU Cooler
if so what midi cases are the best for cooling around the £120 mark
thanks guys
i like the lian li seems a good quality case but its not got a window which i really want will my gear all fit in a case this size ok ? with the xfire 6950s ect
i like the silverstone cases but the only one i like the white rv02 ew has the window on the right hand side which is stupid and means i wont be able to see it :(
you will be able to see it, silverstone rv02 and many more silverstone case have a very unique design.
the rv02 has the window on the right because the mobo is mounted on the left :D
ok guys ive narrowed it down to these cases opinions?
for midi cases
Coolermaster HAF 922 Mid Tower Case Red
Silverstone PS06-W
Coolermaster HAF 932
Lian Li Lancool K62R Midi Tower Red Dragon Lord Edition with Window
Coolermaster CM 690
now with my spec do i need a full size case for the sooling with the xfire card ?
im going to be doing some major cpu overclocking also
will any of these cases provide me with the cooling i need for the gfx cards and cpu or do i need to go to a full size case i can afford and have a full size case i just dont want to spend money on something i dont need >:)
thanks again guys
I've got the 922 and I know the cooling is decent, would be fine for xfire cards. The 932 is a full tower case, although you'll get more space it depends if you really want something that big. Most higher end mid tower cases are fine for cooling xfire setups really, plenty of people on these forums use them.
