Specced my PC. Cant aford it. Overclocked spec to match it though!
13 Jul 2005
I was looking to make a decent PC thats good for games. Didnt want to spend to much and started talk to you guys here, picking parts that are fast and most importantly reliable. I hate when something goes wrong in my PC and i got to send my part off to be replaced and PC is down for a month.
Basically this is what i picked out :
Intel E6400 €230
Gigabyte DS3 €130
Sapphire Radeon X1950XT 256MB GDDR3, PCI-Express, €255
Samsung SpinPoint P80SD 80GB SATA2 8MB 7200RPM €48
Gigabyte GZ-X1 Silver, 4X 5,25", 2X 3,5", (Case) €43
Antec NEOHE 430 GB 430-Watt PSU Low €90
Crucial DDR2 BallistiX PC8000 2048MB CL5 Kit w/two matched BallistiX 128Megx64 €465 Omfg ... really expensive part for the system >.<
So in total €1290 with tax & delivery!
Memory seems to be the biggest place where i spend money i might be able to save by buying something thats cheaper and over clocking.
Is there anywhere else i can save money and can get the same performance by over clocking? If it means i need to spend money getting extra fans etc then it get pointless. I leave the system on 24hours a day, 7 days a week.
Have you any recommendations where i can save money? Are any parts a particular bottle neck? I play WoW a lot on 19inch screen in about 1200-1*** screen mode. So need a nice bit of G-card power.
Thanks for any tips and advice.
Why on earth do you need PC8000? You could easily drop to 5300 or 6400, save yourself £150+ and still happily OC the rig. You could also drop to E6300 or E4300 and you'd barely notice the difference, especially if you're going to OC the rig.
I don't know about the 4XXX chips, but as far as I'm aware, the E6300 is the best Core 2 Duo overclocker by a long way. PC Format got it to almost the same speeds as the Extreme Edition, only it's £600 cheaper.
Don't get the 6400, get the 6300.
Excellent! Will there be much of a performance hit with the lesser RAM?
How safe is it to OC this RAM? I want it to be reliable and last me at least 2-3 years with no problems. I dont mind a small OC but a big greedy OC i dont want to do and end of blowing stuff or messing the system.
Corsair TWIN2X 6400 DDR2, 2048MB CL5 is €236! Seems ok! Could we push that to the same speed (or close) as the PC8000 stuff?
So E4300 or E6300? I done want to almost double the clock speed, but a little OC without extra fans how safe would it be to go on those chips? Again i dont want to harm the system or burn the house down in my sleep. Also will be using all the stock heat-sinks fans as i am skint!
Any thoughs on the Gcard, Mobo and PSU? They ok, or am i wasting money somewhere. I picked them cause they seem well liked by all the guys here at OCUK forum!
Get DDR2-6400 RAM, If you run 1:1 you would have to run 400+ FSB to overclock 6400 RAM. 8000 is not needed.
Woody_FX said:
It was originally €700 but thats never going to fly. Will stretch it to €900 and i cook dinner for my girlfriend on Valetines!
Thats about £630. C2D, 2GB RAM with gaming graphics, just cant be done, but I'll have a try
Van Diemen said:
Thats about £630.
Is it? Oh well, heres my attempt:
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail £95.99
(£112.79) £95.99
(£112.79)
GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit (GX22GB6400DC) £124.99
(£146.86) £124.99
(£146.86)
Antec SLK3000B Midi Tower Case - No PSU £28.99
(£34.06) £28.99
(£34.06)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24) £69.99
(£82.24)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £61.99
(£72.84) £61.99
(£72.84)
Samsung SpinPoint P HD160HJ 160GB SATA-II 16MB Cache - OEM £34.99
(£41.11) £34.99
(£41.11)
Sony DDU-1615 DVD-ROM (Black) - OEM £9.99
(£11.74) £9.99
(£11.74)
Connect3D ATI Radeon X1950 XT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £137.99
(£162.14) £137.99
Total : £676.65
