**Special Deal Creative Sound Blaster X-Fi Titanium HD Sound Card (70SB127000001) **
7 Feb 2011
Stoke on Toast
Due to Creative moving away from THX and launching the SBX Pro Studio range one of their former flagship sound cards the X-Fi Titanium HD is now available at a bargain price of 94.99 Inc VAT
Stock lands on monday.
Creative Sound Blaster X-Fi Titanium HD Sound Card (70SB127000001) @ £94.99 inc VAT
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any sound card Creative has ever introduced and includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio ever produced by a Creative sound card. Replaceable OP-amp provides the flexibility to further customize the audio experience through different sound coloration. If you are serious about your PC sound, this is the ultimate Sound Blaster experience.
- High-Fidelity audio performance D/A, A/D converter with SN ratio of 122dB with 0.001% (THD) distortion
- High quality audiophile grade performance components designed to eliminate noise, while dramatically improve sound field dynamics in high and mid tones
- Headphone out with 115dB, 24bit/96kHz support High-Definition (HD) quality sound for original playback
- Personalize sound field experiences with swappable OP-amp sockets
- THX TruStudio PC effects transforms your experience into a true High-Definition (HD) multimedia emotional journey
- Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over headphones and speakers
- ASIO recording support with latency as low as one millisecond with minimal CPU load. Dolby Digital and DTS encoding enables one-step single-cable connection to home entertainment systems, with included optical cables
Was £157.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Would this actually make a difference to my sound quality?
I'm currently using 2.1 connected to my TV which in turn is connected to desktop by HDMI
I guess the usefulness of a dedicated sound card comes down to the speaker set up people have attached to there PC.
I stopped getting separate sound cards many years ago as the ones on motherboards were just as good for my small surround sound set up.
If you got the money to spend and can buy the speakers to match I am sure its awesome.
Yes Jack the quality will improve and you will more than likely find that the volume is easier to control.
How much it will improve it by depends on your speakers though, a £20 2.1 set up will not respond as well as a £150 2.1 set up.
