Special Deal on TWO! 1250w PSU!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
This is on This Week Only... but it's such a great product with a great sweet price point!
OCZ ZX Series 1250W '80 Plus Gold' Modular Power Supply @ £144.98 inc VAT
The ZX Series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA® SLI™ and ATI CrossFire™ modes, supporting even the most power hungry GPUs with up to triple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
Kept ultra-cool with a load-controlled ultra quiet 140mm fan, the ZX Series was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 92% efficiency at typical load and up to 89% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. The OCZ ZX Series provides universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
Backed with OCZ’s 5-year “power swap” warranty, the OCZ ZX Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 1250W Continuous power
- Ultra quiet 140mm ball-bearing fan
- +12VDC @ 104A Single Rail Design
- SLI™ and CrossFire™ support
- Fully modular cable management system
- 150 x 175 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 80-Plus Gold Certified
- 92% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF: 100,000 hours
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 6 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £169.99 Inc. VAT
Only £144.98 inc VAT.
ORDER NOW
