- 29 Nov 2019
Hey folks,
Just need some advice about getting a 2nd SSD for my partner's PC.
At the moment she only has a 500GB SSD and I wanted to get her an additional NVMe M.2 SSD. Her motherboard is a Z390 Master.
As she just inherited that PC and I don't know much about it, are there specific spec of SSDs that's compatible with it? Can someone recommend some options of 1-2 TB ones?
Also, would there be a specific slot that should go into? I think the GPU she has in is the 2080ti, if that matters in terms of the slots that it takes.
Thanks very much!
Martin
Thanks very much!
Martin
