Hi, I need to build a system to use specific software. The software that will be used is.
Autodesk: Architectual Desktop
Autodesk Vis 2006
The work will be 3D views of basements in large houses and walk throughs.
Would a standard powerfull system running 2 x 7800 GT graphic cards be suitable or would I need specific hardware to use do these tasks?
Any help greatly appreciated
Autodesk Vis 2006
