hi guys, well its been a long time since i was overclocking and had my last rig but been living with a laptop since as had no room, but i wanna start a mid gaming, but fast internet multi tasking pc. and it needs to be quick as ill be getting bt infintiy, and we all hate a slow pc!
soooo.... as im doing this in stages over the next couple of weeks. ive think ive settled on this mother board
http://uk.asus.com/Motherboards/Intel_Socket_1156/P7P55_LX/
or looking around again,
http://www.gigabyte.com/products/product-page.aspx?pid=3503#ov
can get this for £60 new, i know this is 2010 hardware, but like i say i dont need a benchmark monster. just something thats quick and will keep up with most if not all games for the next few years
any way is this motherboard a good choice
i want to go the full 16gb (unless theres no need and say go for 8gb or 12?) specd on this baord on the highest mhz, which is 1600mhz, which also states oc support to 2200, so few things
can some one spec me a cheapish ram that can be oc'd and either a i5 or i7. as theres a few about.
and just sugestions on cross fire quad core gpus, as it states the spec can support quad x-fire.
ill most likley start air cooled, eventually run watercooled and oc the cpu/ram/gpu. yes ok so i said i dont want a monster rig but hey, i wont be able to help my self !!!
cheers
cheers
