Speck Candyshell volume problem
22 Sep 2007
Abingdon
Hi,
I have just received a Speck Candyshell for my iPhone 3GS bought from a reputable dealer on a well known auction site.
My problem is that when the case is fitted to the phone the volume buttons seem to be permanently pressed, meaning that either the volume goes all the way up, down, or somewhere in between after I've removed then put back the iPhone in order to try and get a correct fit in line with the volume controls.
Does anyone else have the same problem with the Candyshell? Its a nice case and I'd like to keep it but at this rate it will be going back due to this design flaw...
