speck check
1 Feb 2009
toon
hi,
anyway of making this cheaper without changing the cpu? it needs to be able to be used for some of the latest games if poss. can go down to a 23' monitor but he says he needs a decent size for gaming and movie viewing.
Intel Core i7 860 2.80Ghz (Nehalem) (Socket LGA1156) - Retail
£231.99 (£197.44)
XFX ATI Radeon HD 4890 1024MB GDDR5 PCI-Express Graphics Card £143.98 (£122.54)
OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 Dual Channel (OCZ3OB1600LV4GK) £85.99 (£73.18)
Gigabyte GA-P55M-UD2 Intel P55 (Socket 1156) DDR3 Motherboard £85.99(£73.18)
OCZ StealthXStream 700w Silent Power Supply £71.51 (£60.86)
Antec 300 Three Hundred Ultimate Gaming Case - Black £43.99 (£37.44)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache £37.99 (£32.33)
Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366) £32.99(£28.08)
Pioneer DVR-S18L 22x DVD±RW SATA Labelflash ReWriter - Black (Retail) £20.99 (£17.86)
Logitech Deluxe Keyboard (Black) £7.14 (£6.08)
Iiyama ProLite E2407HDSD 24" Widescreen LCD Monitor £163.99 (£139.57)
Sub Total : £788.56
Shipping : £13.75
VAT : £140.40
Total : £942.71
advice appreciated. :)
If its just for games, then I would switch the CPU to an i5 750. You will see little benefit from the i7 in games, and using an i5 could save you £90.
I would suggest going for this power supply, Its higher quality and will support your system perfectly happily (its also a touch cheaper).
That Titan CPU cooler will not fit on that board/CPU, you need one which is socket 1156 compatible. I would suggest this.
Personally I would go for the Samsung F3 500GB HDD instead, its only £2 more and super quick.
For the graphics card, you could change it to a 5770. Its a bit slower, but it is also £20 cheaper and supports DX11.
yeah he needs multithreading for the work stuff, which is why i dont want to change the cpu, can change anything else though thanks, duh in my rush i forgot to check the cooler was compatible lol thanks for pointing that out. :) il check out the other suggestions. any more welcomed
ok i have made the changes as suggested to the arctic pro cooler - 18.99
sapphire 5770 gfx - 122.99
Samsung SpinPoint F3 500GB SATA-II 16MB Cache 39.99
corsair 550w psu £68.44
total is now £890
any ideas to shrink it more?
