Specs a business desktop where cost is not an issue
20 Oct 2002
hi,
can you specs me a desktop, that is mainly use for excel and other office tools.
Cost is not an issue; speed, reliability and style are of the uptmost importance. Will not be playing games
thanks
lankor
If you want a business desktop then buy a pre-configured PC from a company with support SLAs and so on...surely don't put it together yourself :confused:
is large comptated excel file and will be running multiple software on the computer. cost is really not an issue as it is for the MD and just want the best performance.
look for a good and reliable 939 motherboard. (require recommendation)
AMD's Dual Core Athlon 64 X2 4400
raptor 74GB
Using some existing ECC ram from server (spare) 2 *512
A graphics card with dvi and vga (require recommendation)
Case (require recommendation)
PSU (require recommendation)
have in house IT team that will setup the computer
generally, those pre configured computer do not give same amt of performance or style as required.
tks
Still, i think a setup like that is overkill for excel related activities, i mean a pIII is easily capable of running it, consider getting a cheap dual core pentium 4 if you think multitasking will have a detrimental effect. As for graphics cards, most have both ports - something like the x800 would be fine i think and is priced around 40 pounds.
tks
Ok, you got me on the style bit :D
already got 2 * Dell 20 inch widescreen
got few asus a8n deluxe here and can take in ECC ram
otherwise, will get some cosair ram
raptor 74GB
to be quite honest mate, your taking the mick :eek:
round not going to see any advantage of a raptor over a regular HDD in windows use (not to that extent anyway)...
CP-151-AM AMD Opteron UP 165 Dual Core San Diego 1.8GHz 2MB Cache (Socket 939) - Retail (CP-151-AM)
£204.95 £204.95
MB-079-AB Abit UL8 ULi M1689 (Socket 939) Motherboard (MB-079-AB)
£24.95 £24.95
MY-005-OK OcUK Value 512MB (2x256MB) PC3200 184pin DDR Memory Dual Channel Kit (MY-005-OK)
£24.95 £24.95
HD-051-SE Seagate Barracuda 7200.9 80GB ST3808110AS SATA-II 8MB Cache - OEM (HD-051-SE)
£30.95 £30.95
GX-027-LT Leadtek WinFast A340TD GeForce FX 5200 256MB DDR TV-Out/DVI (AGP) - Retail (GX-027-LT)
£33.95 £33.95
CA-000-RB OcUK Value Rainbow Series Case Silver With 350W PSU (CA-000-RB)
£19.95 £19.95
CD-057-LO Liteon SHM-165P6S-01C 16x16 DVD±RW Dual Layer ReWriter (Beige) - OEM (CD-057-LO)
£22.95 £22.95
CA-000-XP X-PRO 400W Silent Power Supply (CA-000-XP)
£37.95 £37.95
Subtotal £400.60
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £9.95
VAT £71.85
Total £482.40
if you must have dual core, get the opteron instead... cheaper than the 4400+ and performs just as well.
really no need for 1GB of memory, you could probably make do with the stock PSU as well tbh... but even that spec for an excell and workstation pc is ridiculous....
what do you think of this setup?
Lian-Li PC-6070 PLUS Silent Aluminium Case (No PSU)
ASUS A8N-SLI Deluxe - Mainboard - ATX - nForce4 SLI - Socket 939 -
Processor - 1 x AMD Athlon 64 3700+ / 2.2 GHz - Socket 939 - L2 1 MB - Box
Sapphire ATi Radeon X300SE PCI Express 128Mb Lite-Retail Boxed
Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) CAS2 (MY-079-CS)
Raptor 75GB
Samsung SH-S162A/BEBN 16x16 Double Layer DVD-Rewritable OEM (Black)
Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU (CA-025-EN)
would there be any compatiability issues?
we have some maxtor diamondmax 10 compatibaility issues with asus nforce 4 board
thanks
Raptor 75GB
case fine...
don't bother with the SLi motherboard, too many features that you wouldn't use in a workstation pc...
a 3200+ would probably be just as good (thought you wanted dual core anyway :p)
2GB of ram... for excell and office based apps.... what is this pc really for? are you taking over the world or something?
raptor... quick yes, but again... really needed for office based apps...??? a decent SATA drive, or even a couple in a RAID array would be the same performance for similar (read: less) price.
500w overkill?
IBM Thinkpad T42 with 2GB.
Docking bay for T42
Keyboard and Mouse - select at your leasure.
NEC MultiSync 20WGX2
The T42 will drive the 1680x1050 screen :D
Sorted.
I bet the noise of a Raptor would be, though.
Go for a quiet PC...in other words don't go for the heat monsters that are speedy CPUs. I run some 'old' 2.8Ghz P4 here with the fan on 70% and it's lovely. I can tell you nothing annoys me more than a noisy PC when I'm trying to concentrate :)
