Specs For 2 Games?
11 Apr 2003
Notts
Hi all... Just wondering what the required specs will be for:
Assasins Creed
Devil May Cry 4
Will they run on XP? My current spec:
AMD X2 4800+
2GB Ram
ATI X1950XTX 512MB
Assasins creed is fine ( although not maxed offcourse, recommended specs include an 8800...) and I'm sure DMC4 will be fine too.
Just don't expect more than gfx sliders @ medium-high.
assassins creed
http://forums.ubi.com/eve/forums/a/tpc/f/5251069024/m/7641042236
System Requirements (List both minimum and reccommended):
Supported OS: Windows® XP/Windows Vista® (only)
Processor: Dual core processor 2.6 GHz Intel® Pentium® D or AMD Athlon™ 64 X2 3800+ (Intel Core® 2 Duo 2.2 GHz or AMD Athlon 64 X2 4400+ or better recommended)
RAM: 1 GB Windows Xp / 2 GB Windows Vista
Video Card: 256 MB DirectX® 10.0–compliant video card or DirectX 9.0–compliant card with Shader Model 3.0 or higher (see supported list)*
Sound Card: DirectX 9.0 or 10.0–compliant sound card (5.1 sound card recommended)
DirectX Version: DirectX 9.0 or10.0 libraries (included on disc)
DVD-ROM: DVD-ROM dual-layer drive
Hard Drive Space: 8 GB
Peripherals Supported: Keyboard, mouse, optional controller (Xbox 360® Controller for Windows recommended)
Supported Video Cards at Time of Release: ATI® RADEON® X1600*/1650*-1950/HD 2000/3000 series NVIDIA GeForce® 6800*/7/8/9 series
The specs for DMC4 arnt out yet, but its likely to assume that theyl be similar or less than Lost Planets, seing as LP on the 360 ran at 30 FPS, and DMC4 which uses the same engine runs at 60, so quite a bit of optimization may have been done :).
