Radeon HD 7850 130 Watts
GeForce GTX 660 140 Watts
Difference: 10 Watts (8%)
Memory Bandwidth
The Radeon HD 7850 should theoretically perform a bit faster than the GeForce GTX 660 overall. (explain)
Radeon HD 7850 153600 MB/sec
GeForce GTX 660 144192 MB/sec
Difference: 9408 (7%)
Texel Rate
The GeForce GTX 660 should be a lot (approximately 42%) faster with regards to texture filtering than the Radeon HD 7850. (explain)
GeForce GTX 660 78400 Mtexels/sec
Radeon HD 7850 55040 Mtexels/sec
Difference: 23360 (42%)
Pixel Rate
If using high levels of AA is important to you, then the Radeon HD 7850 is the winner, but not by far. (explain)
Radeon HD 7850 27520 Mpixels/sec
GeForce GTX 660 23520 Mpixels/sec
Difference: 4000 (17%)
GeForce GTX 285 1GB 204 Watts
Difference: 64 Watts (46%)
Memory Bandwidth
As far as performance goes, the GeForce GTX 285 1GB should in theory be just a bit better than the GeForce GTX 660 overall. (explain)
GeForce GTX 285 1GB 158976 MB/sec
Difference: 14784 (10%)
Texel Rate
The GeForce GTX 660 is much (about 51%) better at texture filtering than the GeForce GTX 285 1GB. (explain)
GeForce GTX 285 1GB 51840 Mtexels/sec
Difference: 26560 (51%)
Pixel Rate
If using lots of anti-aliasing is important to you, then the GeForce GTX 660 is a better choice, but not by far. (explain)
GeForce GTX 285 1GB 20736 Mpixels/sec
Difference: 2784 (13%)
Will i see much difference with the 660 to my 285? Ive had the 7850s and had so many problems.
Memory Bandwidth
Texel Rate
Pixel Rate
Memory Bandwidth
Texel Rate
Pixel Rate
It was a link to explain it haha, but id rather someone on here explains the cards since the stats tend to lie.
